    Aug 2003
    Paris, France
    Hi all !
    I have this avi movie which DivX 3 low-motion @ 720x342 & MPEG-1 Layer3 audio (so says Gspot) and I wish to burn it as VCD. Since TMPGenc does not support mp3 audio, I would get the video but no audio as is.
    I downloaded [SCMPX.exe - MPEG Audio layer-I,II,III stream Player, converter] which can be used as external program for MPEG-1 Audio Layer 3 encoder in TMGGenc.
    I tested the TMPGenc / SCMPX setup [Audio stream setting/Stream type set as MPEG-1 Layer 3] for the first 3 mn of the movie. Even though there was a SCMPX encoding at the start of the conversion process, still no audio in the output file.
    Q : Am I using SCMPX incorrectly ? Should I be using it beforehand & independently of TMPGenc ?
    Q : What does [Mpeg split (Video CD is not supported)] (SMCPX feature) mean ?
    Note : I finally used Virtualdub to extract a wav file so I solve my pb with that particular movie but I still wish to know how to use SCMPX within TMPGenc.
    Thanks.
    jacko
  2. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    Mpeg 1 layer three is a an .MP3
    cetrainly you could use any number of programs to convert it to WAV and then submit it to TMPG
    Audio Catalyst
    Ez Cd Creator
    Sound Forge
    Goldwave
    Winamp (?)
    many others will convert this file
    Sorry I can't expain the plug-in to TMPG
    but maybe others can...
    Aug 2003
    Paris, France
    Should one use a separate audio file if possible or stick to one single video/audio source ?
    btw, which is best : wav or mp2 as a separate audio file ?
    Jacko
  4. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    WAV will be better cause its not compressed
    MP2 is another kind of MPEG compression..so with it you gotta take compression off, re-apply--then take off and re-apply again
    VERSUS 2x for the wave
  5. Originally Posted by Jacko_pop
    Jacko
    First of all TMPGEnc supports mp3,mp2,wav and even ac3.If TMPGEnc won't allow audio multiplexed with the video then go to File>MPEG Tools>Simple De-mux and try seperate video and audio(AVI-mp3).If TMPGEnc still refuses to accept audio Simple Multiplex the files,that way you will have a file with an MPG extension.
  6. Member flaninacupboard's Avatar
    Aug 2001
    Northants, England
    The VCD spec does not support .mp3, only .mp2
    it is unlikely your DVD player will play a VCD with .mp3 audio.
