I have a DVD+R data disc that was burned on a PC, can the superdrive read +R DATA discs, just so i can copy the file thats on it onto the mac?
Results 1 to 9 of 9
First let us know which SUPERDRIVE you have
The early superdrives are A03..they will not even mount a DVD+R
the interim superdrives are MATSUSHITA and will read them but only can copy from OS9 -as I've seen +R files look greyed out in the opened view
and the newest superdrives are SONY 500 specially made with the + capability turned off..these certainly read the +discs but some systems have trouble still in OSX.. If this is your problem, try reebooting into 9
and if the os still doesn't see the files proberly, as long as the disc mounts, TOSAT can sometimes make an image from it ok -
I dont have a mac yet
im planning on getting one before the end of this month (probably a G4, 1.25gig, hopefully higher up, depending on $$$)
but most of my friends have Macs, one just bought his recently, a G4 1ghz. he bought it approx 5 months ago, will it be able to read it on that? if not, is there a Superdrive software update that will fix it? Will it work in VirtualPC maybe? (XP Home). or is it just 'hit or miss'? -
There's gotta be a factoid or two that makes this more cut and dried
The only thing I can say Is:
See If you can still get a dual boot machine, then you can wipe OS9 later when you don't need it anymore..
ASSUMING they build DVD+R support into 10.4
because if OSX won't mount the disc. VirtualPC won't see the files either -
so your saying, if it doesnt work in OSX, try OS9? and if that doesnt work, im SOL, unless i buy a DVD+R drive?
thx for the help
Hello,
I have two optical drives in my G4 1.2. The one that the computer came with is a combo cd-r(W) drive toshiba sd-r1312 this drive will read and play DVD+RW data and movies (with the apple dvd player)
my aftermarket pioneer dvdr-105 will not read dvd+RW discs at all.
so basically i think its a drive issue not os. its hard to believe that the sony 510 series drives will not even read the + discs!!
BTW i am using osx only.
Bernie -
I also have an aftermarket 105 (external Firewire), and I had absolutely no problem with mounting and reading the one DVD+RW disc I've tried (and it was one that both of my set-top DVD players choked on).Originally Posted by BernieR
wow! 10.4 What will that be called? Bobcat?!?!Originally Posted by dcsos
hello,Originally Posted by curtw
so this must be the brand of dvd+rw media issue .....
what a pain!
Bernie
Dvd-lab Read Data Size
By Burig in forum Authoring (DVD)Replies: 14Last Post: 19th Oct 2011, 19:41 -
Will A DVD Data Disc Work On Mac As Well As PC?
By blazin-j in forum Newbie / General discussionsReplies: 2Last Post: 2nd Jun 2010, 09:52 -
DVD Pro Lab - Error: Read Data Size
By lapetite_66 in forum Authoring (DVD)Replies: 2Last Post: 23rd Jul 2009, 14:48 -
VB code to read DVD Control Data Zone
By casejustin80 in forum ProgrammingReplies: 0Last Post: 28th Mar 2009, 11:34 -
How Do You Read the Data from a DVD Recorded on a Combo Unit?
By Junkman in forum Newbie / General discussionsReplies: 5Last Post: 4th Jan 2009, 09:27
