I have a JVC GR-DVP7E camera, it's my first and I am newer then a newbie when it comes to doing anything with digital video.
I was looking at some information and the manual of my camera but noticed, according to the JVC website that the GR-DVP7A has an ilink connection, but mine doesn't have it, or at least it isn't mentioned.
Mine has a DV out (and DV in for that matter) connection and a USB connector.
From the manual I figured the USB is used to transfer data from the memory card, but the manual only mentions a link to a TV or VCR for the DV out and unless I read it wrong, it almost indirectly says capturing normal video to anything but the TV isn't possible.
Now I was wondering, to use the DV out on my camera to capture video, would I have to find a cable to hook it up to a video in/DV in on a videocard or video capture card or can I simply take a 4pins-6pins firewire cable to hook it up straight to a firewire connector on my computer.
Sorry for the slightly long post but I wasn't quite sure how to describe the situation/problem.
I hope it makes some sense, any hints/tips are greatly appreciated.
DV in out
this is the I-LINK
you have it
use the cable you mention and start capturing
Use a freeware VIDEO CAPTURE program like SCENELYZER
or use PREMIERE or ULEAD VIDEO CAPTURE 6
(3 of my faves)
dont use the WINDOWS MOVIE MAKER -
Thanks for your quick reply Dcsos.
It was a bit confusing to the information of a different model of my camera explicitly list the i-link which wasn't mentioned in such a way for mine, and the manual was also rather short.
Good to know it for sure though
Excel basic question
By alintatoc in forum ComputerReplies: 2Last Post: 8th Dec 2011, 09:46 -
Basic Video Encoding Question
By crosen in forum Newbie / General discussionsReplies: 9Last Post: 24th Oct 2009, 20:48 -
Basic video projector question
By jbaugh in forum Newbie / General discussionsReplies: 10Last Post: 14th Apr 2009, 02:58 -
Basic Question RE: Video Restoration
By hondaspeedx in forum RestorationReplies: 11Last Post: 10th Oct 2008, 08:43 -
Basic FAVC Question
By Maikeru-sama in forum Authoring (DVD)Replies: 4Last Post: 10th May 2008, 10:56
