I get errors with both the mpeg and mpeg2 reencoders when using nero to make standard compliant discs. It goes for a while (a long while with mpeg2), and then before it finishes I get the error. So far no reply from ahead, so I am wondering if anyone else has worked their way through a similar problem. I don't think it's an mpeg2 problem as the regular mpeg re-encoding doesn't work either. Thanks.
I've been trying to reencode higher rate MPEG1 down to VCD specs (same res), and also MPEG2 at 352 X 480 down to both SVCD or VCD compliant. I believe I read that Nero's SVCD reencodes to 352 X 480 anyway, which is also the res of my capture device. I have not tried to reencode an AVI, but Nero is supposed to be able to fix the mpgs so I don't think that's the problem.
Nero CD/DVD Speed (4.7.7.5) -Error
By bluemoss in forum DVD & Blu-ray WritersReplies: 14Last Post: 12th Jan 2012, 00:08 -
Error Nero AAC - no HC
By albo23 in forum Video ConversionReplies: 1Last Post: 17th Aug 2008, 15:06 -
Video Quality from different encoders--Vegas, Nero, Pinnacle, Ulead, Encore
By sir_rob in forum Authoring (DVD)Replies: 3Last Post: 4th Aug 2008, 12:32 -
NERO burn error
By Budokhan in forum Newbie / General discussionsReplies: 2Last Post: 13th Jul 2008, 21:58 -
Help. Nero error log
By R!ffraff in forum Newbie / General discussionsReplies: 7Last Post: 3rd Mar 2008, 16:22
