Hi all.
I'm converting Simpsons episodes (.avi) to DVD compliant MPG's using TMPGEnc Plus
Now what I'm wondering, is how big I should make the MPG's.
Obviously I don't want to lose quality, but I also don't want to "over-encode" it.
i.e. using a higher bitrate than necessary. Because then I'd just be wasting space on the DVD.
So how can I find the ideal bitrate where I'm not losing quality, but also not encoding at a higher bitrate than required?
Thanks,
Cam
The AVI is capable of being better than the DVD quality
so why not go at highest DVD quality...this practically speaking would mean a VIDEO bitrate of 8million bits per sec with audio at 384 or 224
If this stutters on some of your players, i'll suggest the setting of 6million bits wihich'll play on LAPTOPS and other resource challenged DVD playback systems -
What resolution did you capture in? I find 352x480 2520max ~2000Avg 300Min VBR produces good small file size movies. I bet you could get around 10 episodes / DVD.
But I'd say... Encode the same minute clip with different rates, burn em on a RW, and see for your self.Ejoc's CVD Page:
DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
DVD:
DVDShrink -> RecordNow DX
Capture:
VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author -
what the heck. don't go wasting bits like that. dude, using some optimised templates like the KDVD ones, you can do a whole lotta shiz on one DVD.Originally Posted by dcsos
you're right you wouldn't see it especially in simsons(animation source)
mpg to vob conversion without re-encoding
By dalek6388 in forum Authoring (DVD)Replies: 4Last Post: 22nd Nov 2010, 16:04 -
AVI to MPG for authoring?
By chronic777 in forum Video ConversionReplies: 2Last Post: 25th Sep 2008, 10:43 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 14:48 -
avi to mpg
By zoranb in forum Video ConversionReplies: 7Last Post: 12th Sep 2007, 15:09 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 16:56
