Hi,
I was wondering if someone would be kind enough to give me a hand with this... Any time I try to encode a movie with subtitles, the subs always come out white/gray and partially transparent. Timing, font size, and formatting come through just fine. I've tried loading the .IFO file from the original disc, but there isn't any noticable difference. I've tried this with several discs, by different authoring studios, with the same result. I am using OSex 0.0110a1 to rip the VOBs to disk, and encoding using the menconder option in ffmpegx from there. Any ideas or suggestions would be greatly appreciated.
Results 1 to 13 of 13
That I do. I eventually just started encoding anyway, even though the subs weren't right. I've even tried loading the *wrong* IFO file, just to see what happened (nothing). From what I can tell, it just seems to be ignoring the IFO altogether. Any ideas?Nomally loading the right .ifo file should fix this kind of problems. Use the preview button to check -before- actually launching the encoding.
I am having the SAME problems. Even when I use an IFO file.. any file.. I can sometimes get the color to change but IT IS ALWAYS too transparent.. I really like the app but am forced to use the not nearly as configurable OpenShiiva right now. I have done everything I could think of (except use IFOedit.. because I am on a mac)...
Any idea? maybe someone can send me an IFO that works or is it a known bug?
There is no answer because there is no answer to your problem. You are not the only one to have it.
One day I suggested Major, our beloved guru, to use the way OpenShiiva treats subtitles but it's probably impossible. I must say though I would like to be able to choose the color, the font and so on... as it can be done in OpenShiiva. The results are quite remarkable.
Moreover I guess it's not a priority for English speakers. Pity...
Well ok I will check back in another month or 2. I don't know why I am the only one who has this problem :\ It got even worse today with the subtitles going outta sync on Azumanga....
I will keep using open shiiva and hope that someday I can download a version and it will work FLAWLESSLY... maybe in a month or 2 when I get a Dual G5 I will give it another wirl!
Need black background behind white subtitles Subtitle Workshop
By kinghlg in forum SubtitleReplies: 6Last Post: 13th Mar 2009, 12:18 -
Question why no subtitles using Fair Use Wizard on black& white movie
By jimdagys in forum SubtitleReplies: 0Last Post: 7th Mar 2009, 06:35 -
Create black background against white subtitles please?Achieved won't stick
By max2 in forum SubtitleReplies: 6Last Post: 12th Nov 2008, 14:09 -
Creating a white and "little transparent" box in the DVD menu
By ihmcjacky in forum Authoring (DVD)Replies: 4Last Post: 30th Dec 2007, 22:11 -
Partially missing audio
By DEMNz in forum Newbie / General discussionsReplies: 3Last Post: 10th Nov 2007, 19:15
where can I load the .IFO file? In the load subs box? And is it possible to do this with 1 .VOB file?
