  1. Member vhelp's Avatar
    Mar 2001
    New York
    Hi guys.. Baldrick..
    I've ben debuggin a bitrate calculator of mine for the past few weeks now.
    I'm hoping to release it also on vcdhelp too.
    I've ben trying to duplicate your's on your webpage (below) and seem to
    be running into trouble with the results:
    * https://www.videohelp.com/calc.htm
    1st Issue...
    * CD [1] x [80] - - - Custom size: [797]
    Correct me if I'm wrong, but an 80min. CDR is 700mb (or 700x1024)=719mb.
    But, an 80 min. CDR should be ~700mb, not ~797mb.
    2nd Issue...
    * may not be an issue, but isn't 1 x [74] 74 minutes ?? or, ~640mb
    but is showing as ~738mb <--- note, this sound more like an 80min CDR.
    3rd Issue...
    * And, the [1kbits = 1024]
    This seems to be reversed. You have it as being 1000 as the default, but
    when I try and match it w/ my calc, In my calc app, I have the option to
    switch between 1024 or 1000 calcs. (I created it that way) And, after carefully
    anylising and re-anylising my calc formula, I have concluded that your
    calc is reversed maybe ??
    Here are ALL the numbers I used in your calculator, for your testing:
    [0]hr [90]mn [0]sec - - - Type: [CVD]
    CD: [1] x [80] min - - - Custom size: [797]mb - - - Bps: [1024k]
    Audio bits: [112] kbit/s - - - Custom aud bit: [112] kbit/s x [1] Tracks
    Total video size = 781mb - - - Other ISO files: [0] mb
    Calculated bitrate: [1073] kbit/s ([1099132]bps) CVD max bit: [2720] kbit/s
    Note, if I make the setting, Bps: [1024k] your final result is: 1073 kbit/s
    while my app says: 1101 kbit/s. If I switch my apps Bps toggle to 1000k,
    it will then result with: 1073 kbit/s.
    Thanks for any input on these issues,
    -vhelp
  2. Read the data capacities of CDs: https://www.videohelp.com/forum/userguides/135642.php
    You won't be able to get a workable calculator if you don't understand how data capacities work for S/VCDs.
    As for units, kilobytes, megabytes, gigabytes all work from base 2 (i.e., 1024 bytes = 1 kilobyte).
    However, when we are talking about kilobits per second from bitrates, the convention is almost always 1000 bits = 1 kilobit.
    Regards.
    Michael Tam
    w: Morsels of Evidence
  3. Member vhelp's Avatar
    Mar 2001
    New York
    Thanks vitualis..
    Reading up on link you provided now. I see now, that 1000k is what I
    should have used as default, and now understand a little bit more. Now,
    for more reading up
    Note, there are some calculations that are based on 1024 though.
    I'm wondering if they have anything to do w/ CDR or just conversion for
    things like audio and video size
    If you don't mind sheading some more light, based on some code snips I
    have below ??
    Some Examples:
    // Audio Size..
    // C11=5400, D7=224 ...((5400 * 224) / 8 / 1024) = 147.66 Audio Size..
    // Excel: =(C11*D7)/8/1024
    rlAudioSize := (inLengthSecs * strToint(txt_audioSize.text)) / 8 / 1024;
    Another one...
    // our Actual CD Size.. ie, 700,000 is 711,680 in size or ~712 MB.. ??
    // C7=700, C4=5, D4=1024k ... (711,680); // note, C4=overhead in MB's..
    // Excel: =((C7-C4)*D4) ... 711,680
    inActualCDSize := (strToint(txt_cdSize.text)-inOverHeadMB) * use_1024_1000(trackbar1.Position);
    Thanks in advance,
    -vhelp
