I just authored a DVD from some home movies which I encoded at a bitrate of 8.5mb/s. The video was a little shaky? Is that bitrate too high for DVD or was it my encoder. I encoded the dv/avi file from the Premiere timeline using Procoder.
the dvd spec allows for video bitrates up to 9,800, with the total (video + audio) not to exceed 10,080 at any time.
however, some people have had problems authoring dvdr with bitrates higher than 8,000.
you might try reencoding at 8,000 and see if that corrects the problem.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Ok I'll give it a go. It's only a 10 minute file so it will be easy to do again. I usually use Tmpeg so I also wonder if its not an issue with ProCoder.
TMPGEnc says "clip total bitrate is too high for a DVD-Video" but it's not?
By sasuweh in forum Authoring (DVD)Replies: 24Last Post: 30th Sep 2010, 04:17 -
Using mutiple passes with lower bitrate vs single pass with high bitrate on
By jones24 in forum Newbie / General discussionsReplies: 15Last Post: 14th Aug 2009, 19:17 -
Is the bitrate high enough?
By Weef in forum DVD RippingReplies: 23Last Post: 25th Jun 2009, 11:29 -
TMPGEnc DVD Author Error - Video Bitrate too high
By powerkoala in forum Authoring (DVD)Replies: 9Last Post: 22nd Nov 2008, 12:16 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2008, 00:54
