I am new to this program still, and am wondering if there is a way to retain the chapter divisions on the original dvd when burning to vcd, so it's not one big long movie. Also, if a dvd is longer than one vcd disc, will forty two divide it up respectively?
No, there is not. But...if you use VCD Builder to burn your movie, you can add chapter markers there.Originally Posted by doctor_how
it should. if it fails to do this, just use mpgtx to split the movie.Originally Posted by doctor_how -
Ok, I downloaded VCD builder, and it won't accept bin/cue files. How do I split up the movie if the DVD goes straight to the computer as bin/cue files?
VCD Builder will only accept mpg files. use vcdtoolsX to extract the mpg from the bin file. then use vcd builder to add a menu, add chapters and rebuild the images.
here is a short tutorial i wrote for vcd builder:
http://homepage.mac.com/asauers/.cv/asauers/Public/vcdbuildertutorial.sit-link.sit -
Thanks! Just what I was looking for! I'm chaptering a music DVD, so the songs will be off a bit on the disc as I couldn't exactly get the right time, but at least it's chaptered. If anyone out there knows of another Mac program that is a bit more specific, I'd like to know. Now I have another problem (maybe this WILL end up to be forty two questions
) I ripped a two hour long DVD with 42 and it split it up into two discs, as expected. Unfortunately, the first bin file is 802 or so megs, which I believe is too much to fit on a CDr. Can anyone help me remedy this situation? Thanks in advance.
actually, it should fit on a 700 mb cd-r. you can fit up to 805 mb (i think). have you tried burning it?
oh...another thing anout vcd builder. you can expand the window and that will stretch out the timeline, allowing you to be a bit more specific with your chapter markers.
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 15:50 -
Powersupply questions and fan questions
By yoda313 in forum ComputerReplies: 39Last Post: 8th Sep 2008, 18:08 -
Forty-Two requiring I install BSD Subsystem on Leopard
By Berkey in forum MacReplies: 6Last Post: 12th Dec 2007, 10:13 -
New to DV, I have several questions.....
By Jensen in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 20Last Post: 3rd Dec 2007, 23:10 -
SD to HD Questions
By The Sumerian in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 21st Nov 2007, 11:08
