First I Would Like To Thank Anyone Who Is Reading This And Is Trying To Help!![]()
Ok What Software Should I Use To Make Exact Copies Of My DVD's.
I Need Software With A Decrypter Built In.
I Have DVD Decrypter. But When I Burn It Doesnt Always Work On Standalone Player.
If Anyone Knows An All In One That Makes An EXACT Copy Please Help! :P
Well from what i've heard, I don't think it's possible to make an exact copy without using a ripping tool like Smart Ripper or DVD Decrypter.
You can try using DVD X Copy, which does it all for you, but that usually splits the movie onto 2 DVD's. Then there's DVD X Copy Xpress which does it all for you aswell, but only backs up the movie itself, sans menu's special features...
What exactly is the problem with it not working sometimes on you're Standalone DVD player? What exactly is the method you're using to back up your DVD's?
CX -
you can only make an EXACT COPY if the commercial DVD is DVD5.
DVD-R/+R is only DVD5. if you have a commercial DVD9 (dual-layer), you either:
1) need to compress the DVD9 down to DVD5 to fit on 1 DVD-R/+R disc...however, you will loose video quality, depending on how much you need to compress
go here: https://www.videohelp.com/forum/userguides/141024
or
2) split the commercial DVD9 to 2 DVD-R/+R discs....this method will NOT loose any video quality, but it is NOT an exact copy of the original because the original is 1 DVD, while you have 2 DVD-R/+R discs...
only 2 programs i know that lets you do above is DVDXCOPY and DVDFAB. do a search on those and you'll find them.
Copying DVD movies with a Sony VRD-MC6 Multi-Function DVD Recorder.. help?
By madeyeX in forum DVD RippingReplies: 14Last Post: 17th Dec 2014, 20:36 -
copying from UDF Video DVD to new DVD HELP please.
By SusanBFH in forum Newbie / General discussionsReplies: 13Last Post: 27th Apr 2010, 13:47 -
Free DVD encrypter for copying DVD's? DVD43 won't work for me
By marcias_70 in forum DVD RippingReplies: 1Last Post: 2nd Feb 2009, 03:09 -
DVD copying with Nero - demands DVD/RW disc and still doesn't work.
By gorelle in forum Newbie / General discussionsReplies: 4Last Post: 5th Apr 2008, 04:44 -
Copying DVD
By carper in forum Newbie / General discussionsReplies: 4Last Post: 6th May 2007, 09:41
