  1. Anonymous
    Guest
    By some reason the menu button is not highlighted and I cannot use it.
    Any clues of what or where I might do something wrong?
  2. Anonymous
    Guest
    problem solved, overlook this =)
  3. Anonymous
    Guest
    I still can't get it to work...What did you do to fix it?
  4. Step 1: dubble click the vts to get another vts (you need 2 to make it work not 1 or more then 2 but exact 2).
    Step 2: put a video in each vts
    After these simple steps you should be able to make yourself a menu.
    Greatings,
    Yf
