ive got an optorite dvd writer but when i use nero now it does'nt burn cd it only makes an image file.
when i go to choose recorder the only one there is image recorder.
should optorite be there too?
is there a problem with nero and some dvd writers?
do i need the latest nero?
i would search for answers but the search engine is'nt working and im a bit drunk now
thanks for any replies![]()
did you register your nero??
the later versions of nero have registration codes unique to a brand...so if you were to register your nero with a key that works only for HP, then nero will only recognize HP drives...., not any other brand drives. -
i didnt register nero and what is HP?
nero was working fine with my old cd re recorder but when i replaced it with optorite it doesnt work properly just makes image files.
should i register it? -
HP=Hewlett Packard
i assume you've heard of it...
well, try nero express first....
you will have to pay $$ to register nero -
what is nero express?
so what u are saying is if i want nero to work with my new dvd re writer i will have to upgrade and pay for it?
i cant afford to coz im skint after buying dvd re writer lol
i am able to burn dvd's with moviefactory but i have some games with cue files i want to burn and now that nero doesnt work what other ways is there? the software that came with optorite just puts the cue file on disc and doesnt burn bin file.
