when i hit brouse to open the avi file it says *.avi can not open, or unsupported whay is this?
What do i do
This could be due to a number of reasons. The most likely I recon is the audio in the .avi is compressed.
The best thing to do is to download AVI2VCD, in the .zip file you download there is a program in the folder called 'decompress' or something similar.
If you load the .avi file into the program you can create a new, similar .avi without decompressed audio.
After you have done this you can load it into an encoding software package like TMPGEnc and you should be able to encode it into a .mpeg and create a VCDYAY!!!!!!!!!!!!!!!!!!!!
Hope this helps. -
This link talks about this problem.
https://www.videohelp.com/tmpgenc.htm#problems
Mike
TmpgEnc Express can't open some AVI
By pcb in forum Video ConversionReplies: 7Last Post: 29th Jul 2011, 13:28 -
failure to convert flv to Avi file because of unsupported video codec
By 2thvideo in forum ffmpegX general discussionReplies: 10Last Post: 30th Jan 2009, 12:54 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
TMPGEnc Plus 2.5 saying unsupported??
By Suprman37 in forum Video ConversionReplies: 10Last Post: 12th Oct 2007, 17:51 -
cannot open or unsupported file on tmpgenc
By Donna Stefani in forum Video ConversionReplies: 6Last Post: 15th Aug 2007, 20:31
