i was just wondering, why is it that VirtualDub only utilizes about 10% - 15% of my CPU's power to run? usually for programs that do this, they rely more on memory usage than CPU, but it is also only utilizing about half of my memory, and that's along with WinRAR running as well....i still have about half of my memory free. my guess is that i am being held back by my hard drive speed.
does anyone know what VirtualDub relies on more heavily, and know of any way that i can optimize it to use more of what it relies on?
just for reference, i have an Athlon 2500+ (1.83 Barton core, 333FSB) and 1GB Mushkin PC3200 DDR RAM....and i have two 120GB WD HD's in RAID0 for hard drive space
well it sort of depends what virtual dub is doing.......
if you're processing an AVI to a different codec i would expect 100% CPU usage. if you're using direct stream copy on audio or video or are outputting sound to .wav, then the CPU usage will be low. yes you are held back by hard drive speed in those operations.
Virtualdub only using 25% of my cpu?
By kkiller23 in forum Video ConversionReplies: 3Last Post: 31st Jul 2011, 10:20 -
?- TBC in a SONY Hi8 player active when utilizing A/D pass through?
By DaveP56 in forum Capturing and VCRReplies: 12Last Post: 9th Feb 2011, 17:21 -
Importing xml in FCP utilizing DH_Subtitle?
By leveleyed in forum SubtitleReplies: 1Last Post: 14th Mar 2010, 01:41 -
Utilizing nvidia purevideo hardware accel. for conversion?
By Vchat20 in forum Video ConversionReplies: 1Last Post: 13th May 2009, 19:09 -
CPU-Z reading for Intel Allendale cpu
By budz in forum ComputerReplies: 11Last Post: 8th Jul 2007, 20:33
