Results 1 to 10 of 10
    Dec 2002
    Blackpool, England
    If your avi files are not converting or won't load or no audio after conversion
    the problem could be
    the avi is uses the Xvid codec(use gspot to find out if if it does) [error on file load]
    variable mp3 audio [no audio or long video / large file sizes]
    Here is the best way which i have found to sort these problems out
    The avi uses the Xvid codec [error on file load]
    The simplest way to sort this out is to change the fourCC of the avi file to more compatible Mpeg4 codec like DivX5
    Heres how
    Click the ... to brows for your avi file
    file loaded
    change to divx
    Then click apply
    The best way to solve this is to convert the audio to wav. To do see if you have a vbr mp3 cheak the following.
    Open it in virtualdub and see if says somthing similar to this
    If it does then do this
    Then ....
    Then ....
    Then ....
    Then just save your wave file
    Then open it inTmpg like this
    [/u]
    Inovate Don't imatate
  2. Are you asking a question?
    Are you answering a question? if so whats the question you are answering?
    Ejoc's CVD Page:
    DVDDecrypter -> DVD2AVI -> Vobsub -> AVISynth -> TMPGEnc -> VCDEasy
    DVD:
    DVDShrink -> RecordNow DX
    Capture:
    VirualDub -> AVISynth -> QuEnc -> ffmpeggui -> TMPGEnc DVD Author
    Dec 2002
    Blackpool, England
    sorry my mistake
    i'm answering a question
    i've changed it now
  4. Originally Posted by Sord_Fish
    If your downloaded avi files are not converting or won't load or no audio after conversion
    Bootleg stuff ain't allowed heah, boy!
    My AVI -> Any Format Guide is available here.
    My Frame Resize Calculator (enhanced for Virtualdub) is available here
  5. Originally Posted by funkguy4
    I have seen you post on several occasions accusing members of downloading bootleg material, where there is absolutely no evidence of any illegal activity taking place. There is an abundance of perfectly legal material available to download from the net or P2P. Unless someone states in a post that what they are downloading could not possibly have been obtained legally, please refrain from accusing members of bootlegging.
  6. hey sor_fish can VDubMod decompress AC3 or no? I haven't ever had to so I don't know, but for the others....
    Dec 2002
    Blackpool, England
    the version i have doesnt to my knowledge it can demux the ac3 i know that, i use headac3he, i think thats what its called and that converts ac3 to loads of stuff. Thats the best i have found, i could never get besweet to work properly always got back ground noise and interference bit complicated for a simple encode. ill do a how to on headac3he if you want its really simple
  8. Originally Posted by Sord_Fish
    I know how to work heada3che and have had it for a while, thankks though! I just wish VDubMod could do it since it would be much simpler than having to go make three different files.
    Dec 2002
    Blackpool, England
    yeah it would be nice if vdub could do it, it would save time and confusion
  10. Thanks for the tutorial / info Sord_fish, I think this may solve my problem. You may have suggested it in a thread I started and I just didn't understand. Anyway, thanks again for the guide.
