Hello, I backed up my original movie using dvd shrink, but when I played my backedup movie in my dvd player on the screen there is subtitles, test constantly on the screen. How do I get rid of them ?
So when I backup my dvd's the backed up copy wont have those damn subtitle text things on the screen.
Results 1 to 12 of 12
1. Grab the remote.
2. Press the subtitle button.
3. When the subtitle box appears, press the cursor button once, and it should disappear.
4. Press the subtitle button, to remove the subtitle box.Hello. -
1) are you doing full disk backup or reauthor mode in DVDshrink??
2) if you don't EVER want the subtitles, than you can remove the subtitles permanently in DVDshrink.....select your main movie and then uncheck the boxes under "subpicture" -
Firstly, ty for the replies
i am re-authoring, havent tried a full ddisk yet
Ah under subpicture, ok great
Thank You very much -
when i first use shrink
the subtitles kept coming back on even after i would turn them off
i remove them now everytime i use shrink so i won't have that problem -
@vance43211,
i think DVDshrink's reauthor mode seems to be more buggy than full backup mode. -
so if i did the movies in backup mode i wouldn't have this problem?
if so, that is good to know
but i take them out anyway
because i don't use them -
@vance43211,
not sure on the technical details, but i believe if you reauthor, DVDshrink has to create a whole new set of .ifo files, etc....
but if you're just backing up the full disk as is...there's really nothing for DVDShrink to mess with other than the filesizes...cuz all the files are still present in the right order, etc.... -
I used to backup all my movies with no subtitles.....but then I backed up Sum of All Fears......and half the movie is in Russian...guess where the english subtitles come from
If you to a backup in dvd shrink rather than re-author the IFO's aren't touched as much since, as poopyhead pointed out, all the data is still in the same order."Weekends don't count unless you spend them doing something completely pointless."
Bartman 8) -
Originally Posted by bartman
most subtitles during foreign language speaking are forced
(getting back to Shania12's question) Can't say that I've ever had the problem that subtitles are on by default after doing a backup with DVD Shrink...I've never done a re-author so I can't comment on that method."Weekends don't count unless you spend them doing something completely pointless."
Bartman 8)
ffmpegX burned subtitles are missing with arabic (iso-8859-6) subtitles
By eswenson in forum ffmpegX general discussionReplies: 6Last Post: 11th Jan 2012, 08:22 -
dvdshrink
By Faerel in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2010, 23:07 -
DVD software player- raise subtitles to top of scrn/ simultaneous subtitles
By jimdagys in forum Software PlayingReplies: 8Last Post: 6th Dec 2009, 17:30 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
Once I've used DVDshrink, then what?
By craniac in forum Newbie / General discussionsReplies: 3Last Post: 18th Nov 2008, 17:17
