Hi, I registered SVCD2DVDMPG+ and am trying to use the ac-3 encoder using BeSweet. I know that normally using Besweet GUI I can check "Compress Dynamic Range" and it will make the resulting AC-3 file's volume normal. Without this option in SVCD2DVDMPG+ the audio files are way too quiet. It shouldn't be hard to add normalize and compress dynamic range options since they are just command line switches. ChrissyBoy if you could add these options then it would help out alot. Thanks, James
if you can email me the command line switches you want I'll investigate. You can also use SoftEncode see the History pages on www.svcd2dvd.com for details
This is the command line for Besweet to compress dynamic range, so the switch is -boost( /b2=5 )
This fixes the problem of sound the has already been compressed (mp2) to ac3.
c:\Program Files\BeSweet\BeSweet.exe" -core( -input "f:\file.mp2" -output "f:\file-New.ac3" ) -boost( /b2=5 )
Thanks again, James
Recovering quiet audio
By ReedJohansson in forum AudioReplies: 6Last Post: 20th Mar 2012, 06:03 -
VOB2MPG Quiet Audio
By gfinlay in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 1st Apr 2010, 04:28 -
TSmuxer Audio Trouble - extremely quiet audio (AC3)
By johnp51 in forum Blu-ray RippingReplies: 7Last Post: 24th Sep 2009, 05:57 -
Captured audio low/quiet/soft
By binister in forum AudioReplies: 1Last Post: 1st Dec 2008, 12:18 -
Front panel audio gone quiet all of a sudden
By specane in forum AudioReplies: 8Last Post: 5th Aug 2008, 11:02
