I have done 10-15 svcd with svcd2dvdmpg+, using I guess default setting
my last svcd I did, after burning to dvd, watching the movie in certain spots of the movie I hear loud popping sounds through out the movie. I thought maybe a bad rip, so reripped with isobuster, then reencode with svcd2dvdmpg+ then burn to dvd, watch dvd then same. then I reencoded scvd2dvdmpg+ with one change I added under audio encoder was 2-pass that fixed the problem, the question I have is should the 2-pass be check all the time? was this an isolated problem I had?
Any tips will appreciated.
Lukemon
This happened to me as well, I just leave the 2 pass checked all the time now and I dont have a problem witht the audio anymore at all.
2 pass takes longer but will solve any audio issue you may have. if you look at the build info for 1.0.1265.28718 on http://www.svcd2dvdmpg.com/SVCD2DVDMPG/Software/svcd2dvdmpg+history.aspx that may be a beter solution for you.
tmpgenc 4 audio no AAC encoder?
By sychern in forum Video ConversionReplies: 1Last Post: 22nd Jun 2009, 21:06 -
downloaded video file, has buzzing audio when put into encoder
By efiste2 in forum Video ConversionReplies: 3Last Post: 22nd Jun 2009, 12:55 -
fails to set default audio device using Windows Media Encoder
By George2 in forum Newbie / General discussionsReplies: 0Last Post: 5th May 2009, 00:12 -
HC Encoder vs. audio
By awesomer in forum Video ConversionReplies: 7Last Post: 27th Jul 2008, 21:10 -
Windows Media Encoder broadcasts audio from one PC but not the other
By geek2330 in forum Newbie / General discussionsReplies: 2Last Post: 24th Feb 2008, 12:48
