Hello all,
I have been trying to encode a DV AVI file with tmpge and the end result is a .m2v file. The file should be a .mpg file as SVCD's are because nero does not reconize it and gives me a error.
Any help would be greatly appreciated.
Swing a hammer at it, if it doesn't fix it I gaurantee you will feel better.
an .m2v is an mpg 2 video only file so you need to change the settings to have both audio and video in tmpg
Inovate Don't imatate -
Thanks sord_fish, I didn't even notice it was encoding video only, anyways it worked. Quality was les than a SVCD mind u so I guess i have some playing around with settings to do.
How to convet mpv file to m2v file format?
By Bonie81 in forum Newbie / General discussionsReplies: 4Last Post: 28th Oct 2010, 06:17 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 20:25 -
Only First Segment of VOB File Converts/Encodes
By stevenjgarner in forum ffmpegX general discussionReplies: 2Last Post: 11th Mar 2009, 22:52 -
How to reverse a M2V file
By lorix in forum EditingReplies: 2Last Post: 13th Nov 2008, 04:09 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 14:08
