I just plugged my camcorder (Sony DC TRV-25) to my firewire port (on my Creative Audigy PCI SoundCard) and it intially detected it. After a restart, windows no longer detects the firewire port as it is listed in the "device manager" with a yellow exclamation mark saying...
device type
IEEE 1394 Bus host controllers
Manufacturer
IEEE 1394 OHCI Compliant Host Controller Vendor
PCI Slot 3 (PCI bus 0, device 13, function 2)
Device Status
This device cannot start. (Code 10)
Click Troubleshoot to start the troubleshooter for this device.
any ideas how i can get windows to correctly detect the port or a link for drivers that i could try.
any help would be much appreciated
ice_2003
Put your audigy install cd in the cdrom.
Go through device manager again and rightclick and update the drivers.
Let it try searching automaticly for it.
Pick the CD-ROM option as to where to search.
This will install any last needed drivers to complete and have your firewire working.
Or if there is an option for installing firewire through the CDs autostart window when you pop the CD in. -
FIXED!!!
Piccoro
thanks for the reply
i did actually try this the 1st time round
but i just fixed it after you posted your reply
nothing was working, so i moved my Creative Audigy to another PCI slot, booted my pc so that windows thought everything moved, then without installing, shut down. moved the pci card back, but the audigy disc in, when windows booted, it recognised the 1394 firewire port and im now capping from my camcorder
ice_2003[/b][/i]
How can I capture DV without a firewire port?
By alleyman in forum Capturing and VCRReplies: 4Last Post: 19th Jun 2011, 10:51 -
How can I capture video with no firewire port?
By dickieb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 15Last Post: 22nd Apr 2011, 16:05 -
Sharp Mini DV firewire not detected by Win 7 but was working under Win XP.
By thintin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 6th Jun 2010, 02:12 -
FireWire port has died
By ZiGGY909 in forum Capturing and VCRReplies: 2Last Post: 1st Feb 2010, 07:33 -
Detecting bad capture, detecting blank screen or static in video files
By dj22 in forum Capturing and VCRReplies: 1Last Post: 16th Nov 2009, 00:11
