Hello everyone
I have transfered some television series on to DVD using a panasonic standalone recorder but would like to make multiple copies of these dvds for friends and family.
I am getting a new PC with a Pioneer writer and would like to know what software I should use to copy the dvds created by my standalone whilst retaining there multi episode menus.
I am getting rather tired of burning in real time, and having to stop the recorder after every episode to format the disc with menus.......Using a PC burning in non real time seems like the answer......The panasonic is getting so tiresome in fact that It might take a journey out of my window...lol
I guess the dvds created by my standalone will not be encrypted and will be DVD-5 as they are recorded on 4.7 gb discs. Any help or suggestions greatly appreciated. Retaining the best quality is my main aim so if you have software suggestions let me know
Cheers for now Jonboy
any burning program will work.
make image file and burn image file or use wizard and "copy disk"Jim -
technically, you can do a 1:1 direct on-the-fly copy...but just to be safe, you should just copy the VIDEO_TS folder from the "original" DVD-R to your hdd. you can then burn the folder onto another DVD-R...rinse and repeat...
i personally use nero express to burn DVDs, but there are many other proggies you can use as well....
Convert Multi-episode DVD to 1 avi file
By cfs6254 in forum Video ConversionReplies: 2Last Post: 16th Jan 2011, 02:26 -
Ripping a multi-episode DVD
By scoopyx in forum Newbie / General discussionsReplies: 5Last Post: 21st Dec 2009, 22:55 -
I have a problem with ripping multi-episode DVD
By jemping in forum DVD RippingReplies: 7Last Post: 27th Oct 2009, 11:42 -
Guide Needed for Authoring Multi Language DVD with multi language menus
By kemimich in forum Authoring (DVD)Replies: 2Last Post: 24th Dec 2008, 16:46 -
Multi Episode dvd's with single title, Ripping troubles
By Malicious in forum DVD RippingReplies: 11Last Post: 5th Aug 2008, 09:32
