  1. Any1 know a program that tells u which format ur video is
    etc mpeg1 mpeg2 pal ntsc blah blah
    thanks
    Apr 2002
    The State of Frustration
    You mean like this? (TMPGEnc Plus)
    Hello.
  3. yea like that but is dere another program that is easyer to understand?
    if not where can i get that at?
  4. Tommyknocker,
    I may be incorrect, but isn't that the info for the file you are creating and not the source file?
    Mike
  5. Yeah, I wouldn't call that info reliable at all. I think you're at least half right, Mike. If you select a template that info will be totally different, from my experience.
  6. You can use AVIcodec to find out what kind of video/audio format you have.
    Here's a link
    https://www.videohelp.com/play#identify
    Mike
  7. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    Or try this
    http://www.headbands.com/gspot/download.html
    GSPOT "a codec appliance"
    Apr 2002
    True it does change to the last input. If you are so skeptical, you can always use the "right click select Propperties funstion" of the Ulead products.
    Hello.
