Guys, im really frustrated... ive got a 250 gig hd in pc (runing xp), it allows me 233gig of space, ive just deleted like 5 4.7gig images and yet it hasnt given me any disc space - still shows the same freespace - PLEASE HELP!! before i pull out my remaining few hairs
Results 1 to 9 of 9
Empty the recycle bin and if you have Norton systemWorks installed you should delete the "Norton protected files".
rarely i have to reboot to get the free space reported back properly. XP Pro here.
250 GB hdd???
almost every new hdd states its space in terms of GB=1,000 MB
normally, GB=1024 MB.
so......250 GB hdd = 250,000 MB, since actually GB=1024 MB...
250,000/1024 = 244 GB actual hdd size -
233 GB is correct. They use 1000 instead of 1024 as poopyhead explains, but you must start dividing from the bytes to get the correct GB value.
250 GB = 250 000 000 000 bytes / 1024 = 244140625 kbytes /1024 = 238418 mbytes /1024= 232.8 computer GB -
aww nutz...forgot they carried that all the way to Bytes...hehOriginally Posted by Baldrick
try running scandisk in thorough mode ..... it will fix any errors with free space
the above post i made was a copy/paste for a freind from another forum
while im here i have a question for yas, my hdd is supposed to be 160 gig, but xp only recognizes 133 gig, anyway to get the extra gigs?
@filefeeder,
like Baldrick mentioned...
when the hdd is stated to be 160 GB, that's not in computer terms....
in their terms, 160 GB = 160,000,000,000 B
in computer terms, 160,000,000,000 B = 149 GB
