Now, by reading the various topics on this, there doesn't seem to be a full explanation of how/why this happens, and also how/why to cure it
Occasionally I still get this problem, when converting a DivX to DVD to burn onto a DVD-R, not always, but just occasionally, usually on something that I really want
My methods are :
Extract the audio stream with VirtualDub or VirtualDubMod
Convert the audio stream to 48000, 16-bit, 187-k/sec using DBPower Amp Music Converter, and also apply the adaptive normalize (which is very good at boosting/reducing the overall volume in those crap audio streams)
Convert to a DVD format (MPEG2 NTSC/PAL, whatever the source format is) and output as individual video/audio streams, using 48000,224-bit
audio stream
I use :
VirtualDub
TMPGenc Plus
MainConcept MPEG Encoder (this more than anything due to speed)
TMPGenc DVD Author (mainly this one)
DVDLab (learning how to use this properly)
Nero 6 (don't like TMPGenc's burning engine .. yet)
Quite probably an overkill on the audio, but it gets all the audio streams the same format, and also the normalize does a very good job of bringing back up the sometimes very low volume in the audio stream, but is quite slow as it doesn't do just a volume boost but is selective in what is actually normalized
The audio/video lengths are still exactly the same, so why do I occasionally get the audio out of synch with the video, sometimes nothing, sometimes barely noticeable, sometimes way off
Would outputting as a program stream make any difference to this 'effect', or best to leave as individual streams ?
Results 1 to 1 of 1
[solved]What is the proper way to fix an ac3 synch issue in a h264 mkv file
By yoda313 in forum AudioReplies: 0Last Post: 16th Apr 2011, 10:46 -
8 million reasons not to use Sprint
By deadrats in forum Off topicReplies: 0Last Post: 2nd Dec 2009, 18:46 -
Audio with delay making the proper sync
By ranosb in forum AudioReplies: 1Last Post: 25th Jul 2009, 22:09 -
Need reasons not to buy a Kuro 600A
By KBeee in forum Off topicReplies: 11Last Post: 15th Jul 2009, 13:47 -
Audio At strat in Synch , along of Movie Lost Synch with Video !!!!!
By p_samimi in forum AudioReplies: 9Last Post: 13th Jan 2008, 00:47
