    Jul 2003
    Tijuana, Baja California
    I creating content for bilingual Class, and looked a lot of Tutorial for Permament Sub on the Video, but I need to be Disable/Enable this Subs, I Trial Tested DVDMaestro and it worked kind of fine; but can any kind experience user have a little of time to Reply to this Msg. Thank you all
    :[:[:[:[:[:[:[:[:[:[ My Config ]:]:]:]:]:]:]:]:]:]:
    ASUS P4P800 Deluxe at 3.06c with 800 FSB, 2 Gig RAM Pc3200 @ SATA 120 Gb 8 mb buffer, Sony DVD u10 4+/-R
  2. Hi,
    I would recommend Maestro as well. There is certain procedure how to process and import subtitles in Maestro. Check out the guides in DVD authoring section.
    Enjoy!
