I have a DivX (mpeg 4) CD of a Russian movie "Kin-Dza-Dza". I want to convert it to a format compatible with my DVD player (VCD, DVD etc). I imagine I have to rip it first to my hard drive?? How do I do this? At the moment I can play it on my computer, but with no sound?? Once its on my hard drive I think I can convert it with TMPGEnc & VirtualDub etc. But firstly how do I rip it into a file acceptable for TMPGEnc?? Any help would be greatly appreciated! Thanks!![]()
since it is divx, just copy the file to your drive by dragging it over. load the file into gspot to see what codec you need for the audio. then you should be able to convert it using any of the guides on here.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
Thanks, Conquest, for the quick reply. I drag the file over to my hard drive, but it's an avi file with extension ".vid". This doesn't seem to be supported with TMPGEnc or VDub!? It's a 699Mb 25fps 480x352 (4:3) COL1 video, with 96kps 44.1lHz Voxware MetaSound audio!! Phew! TMPGEnc tells me "unsupported file". Virtual Dub sez "can't locate compressor for format 'COL1" (unknown)". Any suggestions, pal??
Success! I found the solution elsewhere on this site (should've checked more carefully I guess!?)... In case anybody else out there comes across this problem, this is what I did:
1) Open TMPGEnc
2) Click Options/Environmental Setting/VFAPI Plug-In
3) Right-click Direct Show Multimedia File Reader
4) Increase priority to 2
...Now I can open my ".vid" movie file in TMPGEnc and convert to VCD/SVCD/DVD whatever! (Didn't even have to fiddle with the audio, luckily). TMPGEnc rocks! :P
Convert A DivX with AC3 To VCD
By Stinky in forum User guidesReplies: 43Last Post: 23rd Jul 2011, 03:55 -
VCD to Divx conversion
By silverarrow in forum MacReplies: 14Last Post: 18th Feb 2010, 08:25 -
Divx to VCD
By d_unbeliever in forum Authoring (VCD/SVCD)Replies: 16Last Post: 30th Apr 2009, 00:19 -
VCD to DIVX Conversion
By DarkPhoenix77 in forum MacReplies: 2Last Post: 16th Mar 2009, 12:28 -
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 17:01
