I am buying a pioneer 6-series dual format dvd burner, and want to know what should I buy to start having fun. I am going to back-up many hollywood dvd movies, make a few home movies, and transfer vhs and cass. tapes to dvd. Heres my list
1. 20 pack of memorex dvd-r, and dvd+r media, and a few dvd-/+rw discs
2. DVD-X copy for hollywood dvds
3. Dvd srink to srink dvds
4. Anything else?
Results 1 to 12 of 12
From the "tools" section of this site download and install SmartRipper or one of the other rippers offered. I would also at least download "ForceASPI" just in case you have an ASPI problem on your computer (if so then you just need to run it one time).
DVDshrink works well and is free so that's a good choice you already have. Some here have had problems with Memorex DVD media, however I have never used it so I can't really comment on that myself. I would stay away from Verbatim media but TDK is top quality IMO.
Finally if you want to make DVD backup simple then spend a few bucks and buy DVDX Xpress. For DVD burning I recommend RecordNow Max. -
backing up to DVD-R/+R
https://www.videohelp.com/forum/userguides/141024
btw, unlike DVD COPY Express, DVDshrink is free....here's a good guide on it: http://www.doom9.org/index.html?/mpg/dvdshrink2-main.htm -
this might also be helpful if you want to convert vhs to dvd:
https://www.videohelp.com/capturecardsHis name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
Thanks for the tips. I already have a AIW 9700 pro, and am realy shooting on which softwear I should get. Otherwise, is there any other softwear I could use that you recomend, that are free, so I can get the hang of being a nOOb. Also, is there a good softwear to transfer cassest tapes to computer, then to a cdr to listen to in a home cd player. Thx
DartPro 98 or DartPro XP.Originally Posted by neema12
Will record audio from source, apply dehiss/decrack filters, and burn final disc. Excellent audio restoration/transfer program. Not very expensive, under $100 last I saw.Want my help? Ask here! (not via PM!)
I was looking for something that was along the lines of free, if there are any.
you mean like windows sound recorder ?
plus most sound cards come with some software ... -
Sure, but it sounds bad in most cases. No dehiss filters. Yuck.Originally Posted by neema12Want my help? Ask here! (not via PM!)
Where to start? I'm a amateur photographer and I want to start out in video
By James Wright in forum Newbie / General discussionsReplies: 14Last Post: 3rd Jul 2015, 15:12 -
SVCD 2 DVD won't start
By bob witte in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 19th May 2011, 16:34 -
Can you delay the start of the video on a DVD?
By rayden54 in forum Authoring (DVD)Replies: 1Last Post: 22nd Sep 2010, 09:53 -
Why does my DVD start at the wrong stream?
By takearushfan in forum Software PlayingReplies: 0Last Post: 22nd Jan 2010, 19:16 -
auto start DVD?
By netmask56 in forum Authoring (DVD)Replies: 2Last Post: 9th Dec 2008, 06:08
