I'm using the source range feature in TMPGEnc to split & encode simultaneously a downloaded DivX AVI into MPEG2 format for SVCD. Whilst that is working perfectly, the motion on the second disc becomes jerky - not so bad that it can't be watched - but it is definitely jerky compared to the first, which is perfect in every respect.
This has happened a number of times now and I'm wondering if anyone here knows of this problem or if it's a well known issue with TMPGEnc.
Anyone know of another way around this which will make both discs play perfectly instead of just the first one?
Thanks,
DRP
its more likely a problem with the file. the source range should not have done this. scan the file for corrupt frames first.
His name was MackemX
What kind of a man are you? The guy is unconscious in a coma and you don't have the guts to kiss his girlfriend? -
Which tool would you recommend to be the best for scanning for corrupt frames? I know of only DivFix myself but I assume there is something better?Originally Posted by Conquest10
BTW - I may have misled when I said the second disc *becomes* jerky. What I meant to say is that the second disc is jerky. It is jerky right from the very beginning as soon as you press play. It's not as though it just becomes jerky when a bad frame is encountered or something, it is jerky straight away, whilst the first disc plays perfectly throughout.
DRP
jerky motion when deinterlacing - out of sync when not?!
By robotjox in forum DVD RippingReplies: 0Last Post: 11th Jul 2009, 03:51 -
Best tool for PAL to NTSC without jerky motion...using TMPGenc
By funkymix in forum Video ConversionReplies: 3Last Post: 15th Mar 2009, 11:59 -
----jerky motion----when did that happen?----
By ozne64 in forum Video ConversionReplies: 6Last Post: 15th Jan 2008, 05:00 -
Jerky motion
By davidk21770 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 24th Oct 2007, 17:41 -
Jerky action shots or panning motion
By dadrab in forum Video ConversionReplies: 3Last Post: 9th Jul 2007, 12:58
