Lo,
First prob is when I made a dvd-r movie/disk from some vcd's using SVCD2DVDMPG+, the sound was out of sink with the video....by the end of the episodes the sound was 5-10 seconds ahead of the video (starts off fine for the first 2 minutes then goes out of sinc).... (I've only tried playing the dvd-r disks in my stand alone dvd player on my tv and that's where it goes out of sinc, it is compatible with dvd-r disks though)
The settings I choose after selecting the source and destination folders, is to choose "Author DVD Folders" under "Output stream type" (should I choose "Apply Pan and Scan info" as well?).
Then the "Horizontal Res patch value" is blanked out
I leave the "File Suffixes" options alone
And the "Audio encoder" is selected to "MPEG" without the "2-pass" option ticked.
What am I doing wrong?
The Second prob is that when I try to make a dvd-r disk with a bunch of episodes from vcd format, they appear in the wrong order even though they're named with numbers at the end/start of the file name e.g. file01, file02, file03 etc. I've even tried just naming the files as numbers 01, 02, 03 etc. but it appears out of order, and when I try and re-arrange them in the Auther menu by dragging and dropping them in the right order under VTS it rips them in the wrong order when I press start.
What's happening here?
Thanks for any help you can give me,
Arther.![]()
Sync issues have no been added to: https://www.videohelp.com/forum/viewtopic.php?p=544788#544788
Thanks for the first one, will try it out later....any help with the second prob? Should it be in order when I number the files in the right order? or if I re-arrange them in VTS should it be in the right order?
Thanks,
Arther.
bishopthomas@idmc.orgGuest
I am having the same problem with our MXPro Digital Video Mixer using 2 jvc 5000 camera and a jvcbr 3000 recorder, I have treid everything including comminig out the mackie mixer to direct from the mic. someone please help if you can.
field order wrong after AVStoDVD conversion
By 4evrplan in forum Authoring (DVD)Replies: 18Last Post: 26th Aug 2013, 16:59 -
Join video files without reencoding and save/load order of videos
By Danielyt in forum EditingReplies: 6Last Post: 1st Nov 2011, 12:27 -
Subtitles in MKV files out of sinc
By ikarishinji41 in forum SubtitleReplies: 2Last Post: 20th Sep 2010, 16:01 -
AAC to AC3 Wrong Channel Order
By midders in forum Video ConversionReplies: 12Last Post: 27th Nov 2009, 10:45 -
Video and Sound never in Sinc
By techcord in forum DVD RippingReplies: 4Last Post: 30th Mar 2009, 17:03
