Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
  1. Ok. So I know there have been similar questions but I have yet to find the answer to this specifically:
    If I capture from the coax out (digital) of my Laserdisc player to the coax in of my sound card (it is a high end recording card, not SB etc..) during a video capture, I will still have an avi with .wav audio, from what I understand, that .wav audio should contain the proper signal but I need to convert it to .ac3 - how do I do this?
    Just rename the .wav file? or what? If it is already, say, dolby 5.1, then I should not have to reencode right? I dont want it to become 2.0 stereo.
    H'ep, me oh lord jeebus.
    -v20
    "Did you see what GOD just did to us??" - Fear and Loathing in Las Vegas
  2. That might be a challenge. Given that the coax output of a Laserdisc player that provides DD sound is an RF modulated AC-3 signal at 384kbs (I think) and you need a special RF input on a receiver or a special external decoder to process it, I doubt if any PC card would take that input. I do have an external (Yamaha) RF AC-3 decoder - it takes the output from the LD player and internally demodulates the signal and outputs a regular (over coax and optical) AC-3 signal that most DD receivers can handle. If you card can handle this kind of AC-3 signal then that might be a way. Only problem is, once the signal is in your PC (probably some sort of PCM format) what software would be available to process it
