Which will give me the best picture quality Type 1 or Type 2?
I don't recall the DAC having a setting for this.
Don't give in to DVD2ONE, that leads to the dark side. -
RR,Originally Posted by reubenray
From My experience Type 2 seemes to be more compatable with multiple editing programs. Adobe, UL etc... I can't say as to the quality. I have a link to some tele engineers personal website which he writes about all kinds of standards and tech of the TV biz. It's at work, so I'll check it on Monday and see what I can find... But I did find this on the site..
kitty posted 2003 Jan 27 18:42
Digital Video - video captured to a PC from a digital camcorder, often through Firewire. There are two methods of storing DV video data, referred to in this article as type-1 and type-2. Both are stored usually in AVI files. You should be aware of two salient points regarding these respective types to keep in mind when designing multimedia devices and their respective software drivers and utilities:
Any DV stored as type-1 cannot be used with VfW-based editors.
Microsoft provides DV encoder and decoder filters for DirectShow only, and will not provide support for encoding or decoding DV video data for VfW.
It is important to understand the format used to store video and audio in an AVI file for VfW.
Although an AVI file can have n number of streams, the most common case is one video stream and one audio stream. The stream format headers define the format (including compression) of each stream. The existence of one video stream, one audio stream, or both in an AVI file is a de facto standard for VfW.
A native DV stream, on the other hand, interleaves the video and audio data into a single stream. As stated in the introduction, Microsoft is defining two methods (type-1 and type-2) that developers can use for storing DV data in AVI files. The method chosen by a developer will impact the ease with which the data can then be used with current and future video editing applications.
Type-1 Method
The native DV interleaved stream that is produced and consumed in I/O with a DV device contains DV compressed video and pulse code modulated (PCM) audio data. This single interleaved stream can be stored in an AVI file as "ivas" stream (for interleaved video/audio stream). Microsoft refers to this format as a type-1 DV AVI file.
Because the type-1 format stores data as a single AVI stream, type-1 DV AVI files are not compatible with VfW. DirectShow, however, easily handles type-1 data streams by routing the streams to a DV Splitter filter that produces a DV-encoded video stream and one or more PCM audio streams for playback or subsequent processing.
Type-2 Method
Interleaved DV data can also be split into a single video stream and one to four audio streams within an AVI file. Microsoft refers to this format of storing DV data as type-2. This format has the advantage of being backward compatible with VfW, because it contains a standard video stream and at least one standard audio stream.
The type-2 file format requires a small amount of additional processing to split and multiplex the DV stream during the functions of capture and transmit to IEEE 1394 DV devices. MS Info
Free Type 1 to Type 2 Converter from UleadWindows to get a job, Unix to rape clients for $$$, MS BoB for MCM (Mac Cult Members) Mac's for my Toddler to play games on and Linux for the rest of us!
The difference between genius and stupidity is genius has limits. A. Einstien -
If the poster's original question was "Which type of AVI file gives better quality video, DV Type 1 or DV Type 2?" the answer is that the video quality is identical.
You can prove this to yourself by downloading the Canopus DV file converter in the Tools section of this forum. The Canopus file converter is freeware and converts Type 1 to Type 2 and vice versa.
I used to use Ulead Media Studio, which captures in Type 1, and now I use Adobe Premiere, which captures in Type 2. I have produced DVDs from identical DV digital camera source materials using both types of DV files, and I can see absolutely no difference in the quality of hte DVDs created with either DV Type 1 or DV Type 2.
The only difference AFAIK is the way in which the audio is associated with the video, as mentioned by other posters.
The Canopus ADVC-100 produces superb quality video, by the way. I use one and love it. Type 1 or Type 2, either will look great when converted to DVD using a good MPEG-2 encoder like TMPG. -
Reubenray,
OK, I can not find anything that is a difinitive as far as a quality rating on 1 vs 2... The only thing I can find is the post I found and reposted. Basically IMHO, aside from the audio/stream poo poo, its MORE bennificial to use type 2 for compatability. Since Ive been using Adobe Premiere for a few years now I've just let AP handle it and not given it any thought. By default it's a Type 2, but I do use Scenelyzer for importing and sometimes for frame serving and you do need it on type 2 in order to rundirectly into AP6.5.... The Main Concept encoder (Included with AP 6.5) is very fast and gives professional results. TMPG will give you as good a result but is like watching paint dry as slow as it is.... I've emailed a contact I have at Data-Video and Main Concept to see if they can shed any true "gospel" on the subject... Other then what the others posting have said I'm outta answers..Windows to get a job, Unix to rape clients for $$$, MS BoB for MCM (Mac Cult Members) Mac's for my Toddler to play games on and Linux for the rest of us!
