When I play back the video clip with ATI player or window's media player the sound is fine but if I try to edit it with MPEG2VCD or TMPG the sound is way off sync. The only way I found to fix this problem is to encode the hole file with TMPG. I never had this problem with MMC 7.6 only with MMC 8.1 and MMC 8.5
I don't know if it is MPEG2 or AVI your are capturing using MMC 8.1, but I have no problems with out of sync MPEG2's, but I was curious today as to whether or not 8.1 supported AVI Codecs (because 7.6 didn't for some reason) and to my surprise it did, so I could configure them the way I wanted.
Well, I made a few test captures using it and the AVI's played fine, but when it came to re-encoding they were way out of sync.
I think it may be a problem with the way ATI joins the audio to the file to keep it in sync, but when the streams are demultiplexed in TMPGEnc or other programs the audio jumps out of sync.
I don't bother with AVI much but I think maybe frameserving from VD might solve the problem. (Just a hunch) -
Look at this post:https://www.videohelp.com/forum/viewtopic.php?t=171420
F00 says that when you use codecs other than ATI supplied ones, the audio is always 650ms off. Hope this helps.
ATI AIW 9700 pro capture card problem
By INFRATOM in forum Capturing and VCRReplies: 8Last Post: 31st Mar 2009, 11:26 -
No sound problem - internal tv capture card
By planetx in forum Capturing and VCRReplies: 1Last Post: 5th May 2008, 04:38 -
pinnacle 11 - sound capture problem
By lhg033 in forum Capturing and VCRReplies: 3Last Post: 1st May 2008, 19:56 -
Capture problem with ATI Radeon HD 2900 XT in Wondows XP SP2
By redrock1 in forum Capturing and VCRReplies: 3Last Post: 21st Mar 2008, 01:03 -
ATI TV Wonder H.264 no sound
By euthyphro in forum AudioReplies: 1Last Post: 18th Jan 2008, 17:54
