Hi all,
I have finished preping my first VCD to DVD and was going to burn today but the ass wou was going to install my dvd burner got a + and I wanted a - as per all the media I have bought - Grrrr...how annoying!
Anyway i just wanted to check that what i have done is ok to this point and to make sure there are no glaring mistakes or duplication of work.
I used VCDGear to rip the .Dat files to MPEG.
I used TMPGenc to make one large mpeg file of all the episodes
Then Main Concept to make another file(i think this was to encode the file).
TMPGenc DVD Author to make chapters between the episodes. This created a Volume 1 file with the audio and video in.
Now I just need to burn the Volume 1 file to DVD i think - I will probably just use Nero to drop the file in and burn.
One question though. The initial mpeg (after joining with TMPGenc) was only 1.4GB for 3hrs worth of cartoons. After the Main Concept part it was 8GB in size for the same amount in time of cartoons.
Due to this i think im going to have to use dvd shrink to make the file a suitable size to fit on a dvd but it will need a level 9 compression - from what i have read this will effect the picture.
Is the increase in file size like this normal?
Thanks all and thanks to everyone who has answered my questions in the past - with your help im nearly there!!!!!
Best Regards
why don't you put the VCD MPEG-1 files directly on a DVD w/o converting....i.e. make a VCD-DVD.
https://www.videohelp.com/vcddvdr.htm
when you convert your VCD MPEG-1 to DVD compliant MPEG-2, you are just making it compliant with DVD, but you are NOT increasing the quality. the original VCD you have is poor quality (i.e. only 1150 kbit/s CBR). i'm guessing when you encoded the files, you chose a pretty high bitrate for them. however, because your source VCD is already poor quality, you can't improve on it. all the video information is already lost because of VCD's low bitrate. so, when you encode to DVD compliant MPEG-2, you can choose a lower bitrate. what bitrate are you currently using to convert??? try maybe 3-4 mbit/s. that might make the files smaller. maybe you can even go under 3 mbit/s. -
Hi Poopy Head.
I assumed that by converting to DVD Video the picture will be increased but as per your reply that is not the case. I suppose the only advantage of putting the vcds on dvd then is too save space.
Thats fine by me though as my dvd player plays vcds so dvdvcd is no probs.
I just checked the advanced settings on Main Concept which is the encoder and it say 6000 Bitrate. Do you mean reduce it to 3000? If i do this what would happen? -
@tyders,
since VCD specs are part of DVD standard, it would be easiest if you can make a VCD-DVD.
this means you do NOT need to convert/encode...you can directly author the VCD files directly to a DVD...
so, don't worry about any encoders yet...only, if your DVD player for some reason doesn't like your VCD-DVD
go here....the guide is pretty easy to follow:
however, to answer your question:
Originally Posted by tyders
crap in=crap out
so, if..and that's a BIG if, you need to convert your VCD to DVD compliant MPEG-2, you can actually use a bitrate of 3000...maybe even lower...you need to do some testing yourself. since your source VCD has such a low bitrate, there's no way to recover any video quality, so even if you use a lower bitrate to convert to DVD compliant MPEG-2, the video can't be worse off than the VCD.
Newbie question for creating a DVD
By DaBooch in forum Newbie / General discussionsReplies: 4Last Post: 28th Mar 2010, 17:51 -
newbie dvd menu question
By mikeoliver1313 in forum Newbie / General discussionsReplies: 1Last Post: 2nd May 2008, 05:05 -
Newbie question about VCD files for CD-ROM
By donn in forum Newbie / General discussionsReplies: 2Last Post: 13th Apr 2008, 17:37 -
Newbie-Question about DVD Player
By sohancool in forum Newbie / General discussionsReplies: 0Last Post: 20th Mar 2008, 23:00 -
Newbie-DVD format question
By plemal in forum Newbie / General discussionsReplies: 16Last Post: 14th Feb 2008, 14:06
