Results 1 to 22 of 22
  1. Easiest way to join 2 AVI files (same size but different bitrates)
    Nothing more needed. What is the easiest way to glue 2 pieces of AVI together? These AVI files will have to be transformed to MPG afterwards... No VCD or DVD here...
  2. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    why not convert them to mpg, then join them? you can encode them at the same bitrate and specs, and they should make a clean join.
    I do this all the time, I'll have 2 avis that VirtualDub won't see as having the same spec. I trim them up as separate avis, encode and join with TMPGenc. Works like a charm.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
  3. I would rather like to stitch everything and then do a Looooonnnnng encoding session than do it bit by bit. What u think.... I have several dozens rather than a few AVI to stitch....
  4. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    the problem I've found is a reliable software for joining avi's encoded differently... I haven't found any.
    as far as the time, set all your avis up as a batch encode, start it running before you go to bed or before you go to work. I've got a couple of movies encoding right now that will be done about 10 minutes after I get home....
    - housepig
    Housepig Records
    out now:
  5. dvd2avi
    tools on the left. It will frameserve the joined avi's to tmpgenc for encoding to mpeg. I know its not 100% what you want, but it looks like it will get you to your final goal (encoding)
  6. Combine them on premier then export them as one movie file.
  7. Member cplevel42's Avatar
    Feb 2003
    Yes, if you have Premier. I do and this works great for doing a large number of files. What kind of AVIs are these? If they are xvid or divx you are out of luck. The sound will be missing and you will have to remux that back in later or take a different route altogether.
    If they are regular AVIs, you are OK. Are these DV AVIs?
    You said that you will NOT be burning the resulting file to DVD or CD-R. Why not?
  8. GEEZ, haven't any of you heard of VirtualDub. It doesn't matter if the files have a different video bitrate, only audio. If they have different FourCC, and they are all MPEG-4 derivatives, then just go use the FourCC code changer and change it to one of the MPEG-4 derivatives' FourCCs. If you have different audio, just decompress both the audios then load those up with your AVI for video into VDub. It can join things...... all you tryiin' to make the poor guy spend money.
    My AVI -> Any Format Guide is available here.
    My Frame Resize Calculator (enhanced for Virtualdub) is available here
  9. What funkguy4 said...
  10. Originally Posted by State Of Mind
    I second that!
  11. Member cplevel42's Avatar
    Feb 2003
    vdub works too! I have just got into the premiere mode lately.
    Apr 2002
    The State of Frustration
    I still believe AviSynth is the best way. Adds any AVI to as many AVIs as you like, then converts them all to whatever format you want. That "+" operator is a "killer"!
    Hello.
  13. Originally Posted by Tommyknocker
    Could you make an AVISynth scripting guide plz. I know how annoying it is for ppl to ask you to make a guide, but, hell I'm lazy to go find out myself.
    Apr 2002
    I would, but as my boss likes to put it, it would be reinventing the wheel. That is, the guide already exists.
    Hello.
  15. Originally Posted by Tommyknocker
    My bad!
  16. I would say use VDub's GUI to figure out what you need to do and demux your things, then do what you need to do through AVISynth. Makes sense right? Best of both worlds. I gotta make a GUI for it.....
    Apr 2002
    Originally Posted by funkguy4
    My bad!
    Not at all, my esteemed colleague. I just hope he finds it useful.
    Hello.
  18. There are GUIs for AVISynth. There's links for them at the AVISynth website.
  19. Originally Posted by Tommyknocker
    was just gonna say that
    i find AVSynth can join files that VD cant.
    i think coz it frame serves them all as raw video, in its original colour space (?)
    AMD 64 X2 6000+ @3,000 Mhz (stock) | MSI K9N Ultra | Corsair Value/Kingston 6,144MB DDR 667 | 8800GT stock | 3710GB of storage | Powered by Mandriva 2009.1
    Jabber: DaveQB@jabber.org.au
    2.6.29.3-desktop-1mnb
  20. Peck's Power Join (PPJ) is a utility designed to let you combine several AVI clips into one large AVI file. It has a simple point-and click method for selecting the files to be joined, and features a preview capability to view any file or preview the finished clip.
    Hope this helps very easy to use
  21. Originally Posted by ITmauritius
    I know you've prolly found a good tool by now, but I have found "AVI MPEG RM WMV Joiner" to be the best.
  22. I'm pretty sure VDub will join them as long as they have the same frame size.
