What are the necessary preconditions for capturing from Digital Video Camera (Panasonic NV-MX500) to PC (AMD Athlon, Video GeForce FX 5700), using USB. PInnacle software is available? Is it necessary to buy special video card with IEEE-1394 cable?
You can get external capture devices that plug into a USB port but they only allow low resolution (ie poor quality) capture. You don't need a special video card, just a separate IEEE 1394 card (also known as Firewire). In UK they start at about £25 or £50 including editing software. If you are in the US, that price can usually be changed to $.
Capturing Help
By Kyoji24 in forum Capturing and VCRReplies: 4Last Post: 23rd Apr 2010, 07:37 -
What are you capturing?
By ryangarfield in forum Capturing and VCRReplies: 10Last Post: 20th Apr 2010, 15:16 -
Capturing help.
By fuseek in forum Capturing and VCRReplies: 0Last Post: 6th May 2008, 10:49 -
capturing to huffyuv
By nagihcim1 in forum Newbie / General discussionsReplies: 9Last Post: 4th Sep 2007, 21:07 -
Capturing in HD
By The Sumerian in forum Capturing and VCRReplies: 1Last Post: 7th Jun 2007, 12:40
