Heres my problem, hopefully someone can help
I have the following:
AMD 2600
1024 Ram
160 GIG HD
128 GeforceFX with TV out
This is the problem
I have my computer plugged upto my TV via the AV socket and TV out.
I can see everything on my TV fine and movies play great.
If I also plug my computer into my Video, again everything is great.
I really really really WANT to record these movies onto a VHS but when i press record on my video player it looks like its recording fine but when you go to play it back, you just get a blank screen.
Is there something im missing? I have all the newest drivers for my Grafix card.
If anyone requires further information to help me out, let me know.
Any help here would be greatly appreciated.
Vinny
PS Great informative site, keep up the good work
Closed Thread
Results 1 to 13 of 13
I AM A BOMB TECHNICIAN, IF YOU SEE ME RUNNING, TRY AND KEEP UP
Yeah, my video has like channel 1,2,3,4,5,6,7, etc but when you press down from channel 1, it says E and then i can see my desktop on my TV screen,
Thats when i press record and you know the rest,
Thanks for the reply though,
any ideas?I AM A BOMB TECHNICIAN, IF YOU SEE ME RUNNING, TRY AND KEEP UP
Could your TV out be MACROVISION AWARE?
What PLAYER SOFTWARE ARE YOU USING..
Short of getting a MACROVISION HACK for The GEFORCE, you could try a freeware player like
www.videolan.org
for this chore (OUTPUT TO TAPE)
Ive got to be honest,
I DONT HAVE A CLUE what Macrovision is, this is why im in the newbie forum.
Im wanting to play a film (guess he says "I'll be back" and "astalavista baby" the 3rd one) and record to vhs, i thought it would be a simple plug in and go sort of thing, the picture is fine on the tv via the video recorder.
Im using PowerDVD that came with my computer.
If i use another piece of software (suggestions of best ones please) to play my Termy3 would it record on vhs?
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator Craig TuckerI AM A BOMB TECHNICIAN, IF YOU SEE ME RUNNING, TRY AND KEEP UP
go here and you will find all your problems are solved
http://tvtool.info/index_e.htm
Convert old VHS movie to DVD
By sanray19 in forum Video ConversionReplies: 7Last Post: 20th Oct 2011, 13:32 -
capturing vhs for restoration in vegas movie studio platinum
By Michael Rodriguez in forum RestorationReplies: 6Last Post: 28th Mar 2010, 09:38 -
Captured VHS movie and .srt subtitle not sync'd. Any way to fix?
By snafubaby in forum SubtitleReplies: 2Last Post: 17th Aug 2009, 01:52 -
Backing-up Vhs movie tapes to Dvd
By Gerald Sr. in forum Newbie / General discussionsReplies: 4Last Post: 30th Sep 2008, 23:23 -
VHS-recorded movies in Windows Movie Maker
By Line Larsen in forum EditingReplies: 3Last Post: 5th Jun 2007, 07:10
