  1. At the moment i'm using Instant copy to shrink my Dvds then using pdi2iso to change the pdi to iso then burning with Dvd Decrypter.
    I was wondering if there is a way to change the pdi in to file
    coz at the mo if i want the pdi in to file im having to do the above & then re rip it with decrypter just to get it in to file mode.
    Is there a bit of soft ware that can change it in to file?
    i know it sounds funny doing all this but the reason for it is.
    my DVD player works perfect with back up dvds done with DVD Shrink, if i use any thing else the dvd will stutter. So when a film is way to big for Dvd shrink i run it through Instant copy first then rip it back to my hard drive so i can shrink sumthing little like the menu 5% then put it back on to disk so it works ok
    so it would save me a long time if there was a bit of software that can just change the pdi to file.
  2. Member dcsos's Avatar
    Jan 2003
    Y No Werk (anagram)
    Please try PDI tool: freeware from germany makes files from PDI
    http://forum.doom9.org/showthread.php?s=&threadid=47259&perpage=20&pagenumber=1
    from their READ ME:
    PDITool is written in Visual Basic 6.0 and may require VB6-runtimes to run.
    They can be downloaded from this page:
    http://www.karenware.com/powertools/runtimes.asp
  3. D/load the newest verison of DVD Decrypter. It will open the PDI files directly (no need to convert). Just choose "mode | iso - write" and the select the first PDI file in the series.
  4. Hey thank you very much dcsos
    you have just saved me a few hours
    thanks
