I was wondering if there's an easier way to go from DIVX to SVCD without having to waste so much file space in the process. I would like to take 2 DIVX AVI files, merge them into 1, then use DVD2SVCD to get 3 VBR Mpeg2 files ala CCE which would eventually get burned to 3 CDR's.
The (2) source AVI's when combined would give total length of 2h30m. They both have compressed audio and I use Vdub to append 1 to the other but it complains about the audio so I have to take each AVI and save with uncompressed audio in order to do the merge. This result in 1 AVI that is 3Gbytes + which seems all unnecessary since more of the data is audio, not video.
Is there a better tool or easier way to do this?? If I just took each original AVI and made only 2 CDR's (for a 2 and a half hour movie), obviously, the bitrate would be less and quality would suffer.
TIA, synchron.![]()
Results 1 to 1 of 1
AVI - audio remove, video split, music merge
By kj1983 in forum Newbie / General discussionsReplies: 1Last Post: 29th Apr 2012, 02:59 -
VobBlanker DVD Split- Automatically jump to Split Title
By src2206 in forum DVD RippingReplies: 12Last Post: 11th Dec 2008, 07:58 -
Split Mpeg or convert to AVI then split. What to do?
By oldfart13 in forum Video ConversionReplies: 4Last Post: 24th Mar 2008, 00:00 -
Procoder split/split by size/media query
By kippard in forum Authoring (DVD)Replies: 7Last Post: 17th Nov 2007, 22:35 -
Video Convert/Split/Merge Studio
By jos789 in forum Video ConversionReplies: 3Last Post: 5th Nov 2007, 10:32
