Anybody knows how good this writer burns cheap media like Nashua or Creation dvd-r? I know it works well with expensive media...
It wont work with most cheap 1x dvd-r media, cause it can only burn in 2x or 4x.
https://www.videohelp.com/dvdwriters.php?DVDnameid=52&Search=Search&list=0 -
Burns my 1x Princos at 2X speed (with no modification) and can be firmware-patched to support a plethora of what you dub "cheap" media. If you know what you're doing (like a majority of users DO NOT in the media forum) you should have NO PROBLEMS. For the record, I use DVD Decrypter to burn dvd disc images. For audio/video_ts layouts, I burn using Disc Juggler. I don't use Nero, as this drive appears to not like burning to cheap media WITHIN NERO ONLY. Any questions related to this burner, just drop me a PM, I'll be gladly to help. I've successfully burned over 150 Discs with my burner, with my only 2 coasters coming from Nero attempts on my Princos... None of that "over 4 GB" crap either.
Happy Burning
-Freestyler -
Okey...maybe not most 1x dvd-r media....but most RITEK 1x dvd-r media...
this drive refuses to burn dvd-r from Mirror, not sure who the manufacturer is fro thei brand. it burns dvd+rw with no problems.
NEC ND-4550A Problem
By drakster in forum DVD & Blu-ray RecordersReplies: 3Last Post: 3rd Jul 2010, 12:25 -
NEC DVD burners
By RapidRio in forum DVD & Blu-ray WritersReplies: 6Last Post: 6th Jul 2007, 21:07 -
NEC DVD Drives
By RapidRio in forum Newbie / General discussionsReplies: 1Last Post: 5th Jul 2007, 13:13 -
NEC 4571A problem
By rmorrison1 in forum DVD & Blu-ray WritersReplies: 18Last Post: 1st Jul 2007, 12:35 -
NEC NDH81
By babagoi in forum DVD & Blu-ray RecordersReplies: 0Last Post: 24th Jun 2007, 19:05
