I capture video from Sony Digital(DCR-IP210E) to my harddisc via USB.
I work in Easy CD Creator 6 for later burn to DVD.
Problem: The sound in the video is delayed and not longer syncronised
with the picture.
What can I do to capture and burn sound and picture(and later show on DVD) as it is in my camera or as it is if I look att the film at TV direct from camera?
Is connection via a 1394 firewire cable my solution?
Very greatful for help!!!
Edit your movie using Premier. You can unlink the video and audio and you can move you audio to the exact sync and export it as movie file. Now you can burn it on DVD.
Thanx very much - I´ll try that!
Should I also change connection from USB to 1394 firewire cable?
Have a great week-end!!! -
USB or 1394 is no problem, whichever you choose as long as you capture the movie.
Diamond Video Capture VC500 Problem + Settings
By Firelance in forum Capturing and VCRReplies: 1Last Post: 18th Feb 2012, 05:04 -
Problem:Using Video Capture Card for capture or spy another PC.
By gmchn83 in forum Video Streaming DownloadingReplies: 1Last Post: 15th May 2009, 15:56 -
HD Video capture > DVD problem
By JohnnyC3 in forum DVB / IPTVReplies: 4Last Post: 5th Mar 2008, 18:20 -
Problem with 480p capture. Video seems squished...
By Mysteriouskk in forum Capturing and VCRReplies: 11Last Post: 9th Feb 2008, 02:24 -
Cable video capture problem
By spork985 in forum Capturing and VCRReplies: 9Last Post: 23rd Dec 2007, 14:59
