I want to backup Narc. Movie only.
When I use DVD shrink and cut off some of the credits the movie fits on one dvdr perfectly, no transcoding needed. I know dvd shrink does not remove the layer break and dvd2one does, but dvd2one does not trim the credits.
So I was wondering can I cut some credits with dvd shrink and then pass the movie again through dvd2one, will this remove the layer break?
Didn't know shrink leaves the layerbreak in there... does that mean when you're watching the thing, there will be a 1 second pause at that point? I have never experienced that.
If you need to save space, can you strip out some audio/sub data?http://encoding.n3.net <-- for all your DVD and CD backup needs! -
The "layer break" is an arbitrary term.
It's a physical shift from one layer to another, but once the data is all ripped to your hard disk, it's moot.
To say that DVD Shrink "doesn't take out the layer change" is like saying that Winzip "doesn't take out the floppy change" after you've concatenated all the disks of an old image. It's just silly.
- Gurm -
Originally Posted by Pete McCall - moderator cdfreaks
Originally Posted by Gurmhttp://encoding.n3.net <-- for all your DVD and CD backup needs!
Problem: DVDShrink > DVDDecrypter - Layer Break Issue?
By Dave Stewart in forum DVD RippingReplies: 32Last Post: 27th Jun 2010, 20:18 -
How to DVDshrink 7GB of video to DL DVD that handle layer break ?
By SingSing in forum Newbie / General discussionsReplies: 3Last Post: 25th Apr 2010, 15:53 -
DVD-9 Layer Break Question (PGCedit)
By sdsumike619 in forum Authoring (DVD)Replies: 8Last Post: 22nd Jan 2010, 18:19 -
Burning Double Layer DVD with no Layer Break.
By aspen matthews in forum Authoring (DVD)Replies: 12Last Post: 24th Oct 2009, 13:26 -
Retail Layer Break and Imgburn Layer Break..the same?
By Moontrash in forum MediaReplies: 2Last Post: 14th Jun 2007, 12:27
