I know someone out there can help me. I have a 55 mg video in .rm format that I want to put into .avi format. I tried to do it with Tinra but it seems to have only converted half of it, a 2 gig file. What's worse is that whenever I used VirtualDub to sync the audio and video framerates, the resultant video- on playback- seems to be going twice as fast as it should be. Does anyone know what I can do to remedy this situation? Thanks.
- Cory
Ok Rm is not a good quality format and if your converting it as a vcd to play on tv it may not be worth it but here goes.
you can get a hold of Real Producer Plus which has a Realvideo Editor
open your rm in the editor and you can split you rm into smaller section of the rm eg.. if the full size of you rm 9minutes long you can split you rm into three 3minute rm files and then convert them with Tinra and use Virtual Dub to Synchronize the audio to the video
hope that helps
- Cory
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 18:30 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 06:56 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 16:38 -
ffmegX v0.09w and converting avi videos into avi.ff.avi videos
By paddymick in forum ffmpegX general discussionReplies: 2Last Post: 3rd Nov 2007, 00:10 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 13:49
