Other than the obvious larger hard drive, any other compelling reasons to sell my DMR-HS2 and get an E80H?
I was also wondering if the menus were the same on both recorders.
-Max
1. No black level bug on the E80
2. High speed dubbing without re-encoding from the HDD to a DVD-R in Compatible mode
3. Manually add chapter marks to a DVD-R when dubbing from HDD in Compatible mode
And yes, the E80 retains the spreadsheet style menu (finalized DVD-R) of the HS2. -
and the negative .... the DMR-E80 also omits the Firewire input which the HS2 has. Maybe you don't care about this.
ktnwin - PATIENCE -
Originally Posted by ktnwin
Yes, there will be more models coming out that will combine Firewire and HDD, but will they be more affordable? Probably not.
I don't see the firewire as that big of a deal. The notice of quality from your home camcorder using RCA plugs versus a firewire connection is very, very, very minimal. You won't notice it at all.
If the firewire allowed high speed transfer to the HD, or use the camcorder tape and see it as another HD...then it would be another story.
I can't see any reason to absolutely insist on the firewire connection. -
Originally Posted by scamp2032
Bob -
Originally Posted by Gil T Pleasure
VLC looks washed out compared to WMP
By stringcheesy in forum Software PlayingReplies: 3Last Post: 11th Sep 2011, 23:27 -
DMR-E80H Dead
By pbt1234 in forum DVD & Blu-ray RecordersReplies: 27Last Post: 7th Oct 2009, 21:35 -
DVD-rip compared to VHS
By Digiface in forum MediaReplies: 7Last Post: 4th Aug 2008, 12:34 -
Panasonic E80H trouble...
By Captain Satellite in forum DVD & Blu-ray RecordersReplies: 2Last Post: 3rd Aug 2008, 10:36 -
DVDlab Compared with TDA
By loster in forum Authoring (DVD)Replies: 7Last Post: 30th Dec 2007, 19:34
