i need help looking for a dvd burner im looking for the best support +_rw and the cheapesti was thinking of getting NEC ND-1300A 4X DVD±R/±RW DRIVE INT EIDE DRIVE for 160 but when they say bare drive does that mean i have to get my own jumper cable and eide cables and drivers. thanks for ure help in advance
A bare drive is just what it says.
So to answer your question, yes, it is just the drive. You hafta download all the drivers, cables, etc, etc.
$160 aint a bad deal, go for it.THIS has been an RVL123 production... -
alright now i have a few problems they dont ship outside us and im in canada and i only have a 800mhz 64mb ram so is this expectable for burning dvds i have captured and burned to svcd before and turned out great. PLZZ HELP
You may want to get more RAM.
800Mhz should be enough.
Dunno about ur shipping problem m8.THIS has been an RVL123 production... -
Buy some more ram, it's dirt cheap these days. The NEC ND-1300a drive is a good drive at a bargain price IMO.
Be aware that if it's a bare drive it won't have any software for burning DVDs. You'll need to buy something yourself or use free software, that may affect your entire purchase price. When I got my bare drive I already had EZ CD Creator Platinum 5 for DVD-Data, but I found that it would not burn DVD-Video at all. For DVD-Video I bought an OEM copy of Nero Express from www.softwareoutlets.com for $8. Unfortunately they no longer sell the OEM Nero Express there (last I checked - they may have it again).
Philbiker
Removed Esata drive and replaced with another drive. New drive is now unus
By cal_tony in forum ComputerReplies: 6Last Post: 7th Feb 2012, 15:17 -
DVD exploding inside the drive from a drive exceeding 24x. True?
By snafubaby in forum MediaReplies: 10Last Post: 5th Dec 2010, 19:05 -
Compress hard drive to save space/Index drive for faster searching?
By orfajackson in forum ComputerReplies: 3Last Post: 31st Aug 2009, 18:55 -
Time/Date Stamp - DVD, Hard Drive, and/or flash drive camcorders
By vanjh9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 2nd Feb 2009, 19:38 -
Is It Possible to Make Multiple Drive Images on One External Hard Drive
By drstew in forum ComputerReplies: 17Last Post: 24th Nov 2007, 09:47
