I have used VirtualDub to seperate the video and audio from a Huffyuv-captured AVI file so that I can run it through Gordian Knot to encode the video to DivX. Well, when I select the video file that I want to encode (one of them is 4.95GB in size, and the other is only 481MB), the window that is supposed to show the preview and allows you to see where you are cropping the video just shows a blank tan-colored box where the picture should be.......and the length of the video is only being reported in Gordian Knot as 17mins 2 secs, but it is actually almost 43 minutes long.
Does anyone know what would cause this? It's really starting to annoy me, cause I can't get any encoding done.....![]()
Hi xunil76,
Go to the Huffy config options (I usually access it via Virtualdub - Video, compression), and tick the "Always suggest RGB for Output" box then try to reopen the file in Gordian Knot - it should work then.
hope this helps,
cliffo -
sweet, that worked like a charm.....thanks
i never would have guessed to do that......
*Edit*: will checking that option affect my TV Caps in any way, or does it just affect playback? -
nah dude,
It will be fine. I have it checked all the time for my caps and haven't noticed any problems with it.
cheers,
cliffo
Problem with Gordian Knot
By eliqush in forum Video ConversionReplies: 3Last Post: 7th Jul 2009, 20:35 -
Auto Gordian Knot is converting to divx in 4 hours!
By szalaikornel in forum Video ConversionReplies: 8Last Post: 17th Jan 2009, 08:39 -
Major problem loading audio from AVI file into Auto Gordian Knot v 2.45
By robo5050 in forum Newbie / General discussionsReplies: 1Last Post: 7th Nov 2008, 07:12 -
Problem On Encoding DVD to H.264 By Gordian Knot
By bugsboney in forum Video ConversionReplies: 6Last Post: 27th Jul 2008, 10:52 -
Gordian knot sound problem !!
By markos in forum DVD RippingReplies: 3Last Post: 22nd Nov 2007, 04:58
