  1. Hi m8s!
    I'm a total newbie to VCD. Just bought a Limit 8080SE from Richer Sounds in UK. VCD is fine, MP3 fine, but when I try to play Chicken Run DVD the picture flashes light and dark continually. The DVD works fine on my PS2, so it's not the disk. But I do have the Limit connected to my VCR input and from there to the TV; is it Macrovision protection that's affecting the picture quality?
  2. It definitely sounds like Macrovision. Hook up the DVD player directly to your television if possible.
    On 2001-09-29 17:27:37, mopezone wrote:
    Hi m8s!
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
  3. Yup, it's macrovision alright...
    Sep 2001
    Japan
    Look here for an solution to any macrovision problem:
    http://forum.cyberhome-help.de/viewtopic.php?opic=324&forum=6
  5. Thanks guys! Took your advice and it's sorted!
