I RECORDED A DVD ONTO A DVD +RW AND IT WORKED ON MY HOME DVD PLAYER, USING SVCD FORMAT. BUT WHEN I COPIED IT TO MY DVD +R DISC, IT DIDNT WORK. ANY SUGGESSTIONS ON WHAT FORMAT TO USE FOR A DVD +R DISC?
YbaSteveGuest
Did you check the player list to see if your player plays dvd+r cause i know sony players will only play dvd+rw, dvd-rw and cdrw.
Greatings,
Yf -
What are you burning with?
[loose the caps]SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
CoolBGuest
I burn with Nero 6 ultra as dvd-video, and it played on my apex ad-1200 but not my jvc xv-n44sl. Not that it really matters much to me as I am going to stick with dvd-+/rw disks, I was just wondering if anyone had any feedback.
Cheers and good burning!!
CoolB -
CoolBGuest
The apex playes both no problem, the jvc is new but says it has a built in pal to ntsc converter, and has played all pal and ntsc so far.
Cheers
Help me copy from VHS to DVD+r ti work in both PC and DVD player.
By sayger2 in forum DVD RippingReplies: 15Last Post: 14th Jan 2011, 17:05 -
DVDFab Blu-ray Copy vs. DVD Copy
By coody in forum Blu-ray RippingReplies: 1Last Post: 11th Oct 2010, 13:33 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 08:26 -
How can I copy a copy-protected DVD and have only ONE VOB file
By Aafour in forum DVD RippingReplies: 3Last Post: 6th Oct 2008, 01:31 -
Unable to copy copy-protected data DVD
By J_Kirk in forum ComputerReplies: 9Last Post: 22nd Jan 2008, 12:23
