    Dec 2002
    New Hampshire
    OK, Yuk it up everyone... I'm about to post a silly question....
    I need to create 50 DVD's much more then I have done in one run in the past. I used DVDit PE to author my dvd and burn it. But with 50 this will take some time.. I have Prassi PrimoDVD also. I guess my question is can I create an ISO image to master my DVD's from? I can create a DVD folder with DVDit PE, But when I burn it it will not play... I've been looking in the guides section and can't seem to find my answer... Can any of ya help me out?
    Windows to get a job, Unix to rape clients for $$$, MS BoB for MCM (Mac Cult Members) Mac's for my Toddler to play games on and Linux for the rest of us!
    The difference between genius and stupidity is genius has limits. A. Einstien
  2. I am not quite clear on what you try to do , my guess is you want to make 50 copies out of your home made DVD. This is correct then
    1) use DVD Decrypter to copy your DVD to hard drive as ISO image
    2) use DVD Decrypter to write the ISO image on a blank DVD, repeat this step for 50 of them.
    ktnwin - PATIENCE
    Apr 2002
    The State of Frustration
    I would farm it out. At 80 cents a disk, you can have it done for $40.00, and still have a life.
    Hello.
    Dec 2002
    New Hampshire
    Tommyknocker, Ktnwin,
    Thanks for the suggestions. I think I'll try the DVD Decrypter method first. I have 4 Pioneer A03 drives so that should be pretty quick with a master ISO. But if I where to use DVDit PE it would take a lot longer... If it does get to be slow goin I'll send it out... I have a week before they are due.. Thanks again!
