I've been looking for an inexpensive DVD burner for my Pentium III, 500 mHz computer, and the ONLY one I've found is the Cendyne/Verbatim model VBTDVRW1A that sells for about $140 on the net.
I know the models' minimum specs say 500 mHz, but before I order it, it would be good to know that it should work.
Thanks.
you meet the min. specs .. it should work ...
if its any help to you .. ive burned dvd's with a dual 333 system and never had a problem .. -
instead of investing in a DVD burner that probably wont work right in your setup you might want to put a few $$ into a new CPU.
the problem with that old of a CPU is your RAM is probably old too which means your throughput for data is probably very small and the slightest thing will cause a failed burn -
The ability to READ a DVD (either video or general data) disk works just fine. Trying to record (i.e. backup data files) data to a DVD-R on such a slow PC is marginal at best. Many times the buffer under-run feature saved the burn. Recording Viedo... forget it! Buffer under-run portection was overwhelmed in the first few minutes when burning video.
I put my Cendyne DVD-R/RW burner in a Athalon 650mhz system and came up with the above listed findings. The system has 512mb ram and a SIS305 based 64mb video card. The drives were all ATA100 and configured for maximum transfer speed. The hard drive wwas a IBM 60gb 7200rpm drive.
I couldn't think af any way to make the slow CPU system run any faster.
Hope this helps. I didn't bother with anything slower than 650mhz.Only 3 things are certain in life... Death, Taxes, and SPAM. Of these, only Death seems affordable!
SVCDummy -
I have always questioned "minimum specifications". To be on the absolute minimum of the specification should always be a concern.
That being said I don't feel that comments as it relates to this issue will ever be comfortable advice for the poster. It is pretty much a try it and see if it works situation. -
[add]
You can get a +/- combo nec 4x drive from newegg.com for $30 more or $170 shipped. They also have an NEC + drive for $135 shipped.
[/add]
I'm burning right now at 2x. My task bar cpu info never goes above 1%. Well maybe if I open a pdf. Photoshop would probably lock my machine. -
Actually I could burn fine with my Pioneer A05 on a lowly K6-2 450, just only at 1X. Fine enough till I was able to get a faster system, just wasn't fast enough to convert, only burning was fine though for limited use.
Alan
Need a fast ripping dvd burner with lightscribe
By hellbringer in forum DVD & Blu-ray WritersReplies: 7Last Post: 13th Nov 2007, 20:46 -
IDE DVD Burner VS SATA DVD Burner
By mn072065 in forum DVD & Blu-ray WritersReplies: 13Last Post: 13th Nov 2007, 20:15 -
My burner used to burn fast enough...but now it doesn't
By Auto Ford in forum DVD & Blu-ray WritersReplies: 7Last Post: 6th Nov 2007, 17:10 -
Divx won't fast forward fast! What's wrong?
By Hank Kinsley in forum Newbie / General discussionsReplies: 8Last Post: 23rd Jul 2007, 19:49 -
.wmv movie file couldn't fast forward/fast seek?
By tigerb in forum Newbie / General discussionsReplies: 1Last Post: 10th May 2007, 20:43
