  1. When I try to delete an email message from my inbox or view my deleted messages I get this message come up.
    Where do I find the inbox repair tool ?
    My system keeps crashing, the good old BSOD. I think it may be a bad memory stick which is corrupting my data just not got round to checking it yet.
  2. http://support.microsoft.com/?kbid=197315
    :edit
    From Outlook help file
    Scanpst.exe is installed when you install Microsoft Outlook and is located at:
    drive:\Program Files\Common Files\System\Mapi\1033\
    For detailed information about running the tool, see the Help file, Scanpst.hlp, at the same location.
    Note Use Scanost.exe, the .ost integrity check tool, if you get error messages when you synchronize your .ost file with the Exchange server.
    :edit 2
    Hope you're not on a MAC running Outlook 2001
    Originally Posted by jagabo
